Memshield | on ElectriciansForums
Discuss Memshield in the UK Electrical Forum area at ElectriciansForums.net
Risteard
Supporter
V.Nearly Esteemed
Derry, Ireland
[ElectriciansForums.net] Memshield
Have a job to price with the following DB. I'm presuming from the existing devices that it is Memshield 2. I presume Memshield 3 won't be compatible with it?
Yes that's a memshield 2 board, and no memshield 3 devices are not compatible, this is a source of great annoyance and one reason a lot of us moved away from MEM gear.
Mem2 devices are still available but they charge a premium for them.
What devices do you need, someone might have some new old stock.
Ideally a C32 RCBO, otherwise a C32 MCB with an external RCD. Must check through some of my old MEM stock to see whether I have any MEM2 devices.
Reply to Memshield in the UK Electrical Forum area at ElectriciansForums.net
Just stick the 63amp fused connector before the Henley block , or Lucy block as you call it, and your all good, as for your 2nd point, , the...
Double pole switches? Mounted on a grid module? Ignore the fact they have a N stamped on them. Or is your 2 gang switch decorative, and you...
