MERLIN GERIN Multi 9 4P RCD RCCB 100A 300mA | on ElectriciansForums
Discuss MERLIN GERIN Multi 9 4P RCD RCCB 100A 300mA in the UK Electrical Forum area at ElectriciansForums.net
M
mtraczykowski
Does anyone know if there is a common problem with the Merlin Multi 9 RCCB 4 pole 100Amp 300mA, not tripping as we have replaced an existing unit with a new one but the issue is the same,
Many Thanks
Mark
Have they disconnected all loads from the RCD?
Are they testing on the load side of the RCD?
Have they tried to test it with a temporary test lead connected to it? As sometimes they wont test directly on to the terminals.
So has the Electrician now refitted the original one back in as i suspect their was nothing wrong with that one either or is he now going to rip the customer of replacing a part that probably was ok.... had he known what he was doing in the first place the customer wouldn't have been lumbered with an extra cost.
Im also Ghastly flabbered!
Now why did that go through my nasty suspicious mind?
Reply to MERLIN GERIN Multi 9 4P RCD RCCB 100A 300mA in the UK Electrical Forum area at ElectriciansForums.net
