Discuss Merlin Gerin RCBO options? in the UK Electrical Forum area at ElectriciansForums.net
Looking at pictured of them they lack a flying neutral lead but have some clip, presumably the "plug on neutral (PoN)" feature. Any idea how that would be handled with an older board like the above?Schneider Acti 9 iC60H fit the Multi 9 boards.
That as another nagging feeling. I have also had the odd bit of older stuff fail when trying to fix it due to brittle plastic, and I found a split blanking cover as well suggesting someone broke it trying to do something in the not too distant past.I would also recommend replacing the board, merlin made good stuff but its quite common to find the older boards have plastic parts that are deteriorating and have gone brittle.
Some of the most reliable kit on the marketSchneider Acti 9 iC60H fit the Multi 9 boards.
I should hope so, as it's some of the most expensive kit on the market!Some of the most reliable kit on the market
Reply to Merlin Gerin RCBO options? in the UK Electrical Forum area at ElectriciansForums.net
