MET on a TT system? | on ElectriciansForums
Discuss MET on a TT system? in the UK Electrical Forum area at ElectriciansForums.net
zedess
DURHAM
Going to do a consumer unit change and earthing upgrade on tt system for my coming assessment in two weeks,straight forward enough.. all earthing straight to the consumer unit..untill i look in the IEE ELECTRICIANS GUIDE TO THE BUILDING REGS..which shows a main earthing terminal, and 16mm to the consumer unit ( as per TN systems) which way would u go for an assessment ? does it make any difference? thanx
As long as it can be easily disconnected for testing then external MET (labelled correctly) or CU is fine. Many people go for external MET as it can be awkward to get out of the CU block, but personally, I prefer keeping it all in the CU.
yeah either way is fine. External or within your CU both terminals are officially METs, all you are doing is extending the capacity of the MET by adding the external one, dont forget for the external one you should have a warning on or near saying " safety electrical connection - do not remove"
My preferred installation is always to an external MET. Everything accessible without having to start taking CU/DB covers off and fighting your way through dressed cables to disconnect earthing and bonding cables for testing!! lol!!
Totally understand where you are coming from with this, and with some CU's which are very awkward, I go external. I generally install Crabtree starbreaker units and find it quite easy to get to the MET inside.
Each to their own tho :)
Reply to MET on a TT system? in the UK Electrical Forum area at ElectriciansForums.net
To give you some idea....with my DNO, the question "Can you see arcing, sparking or smoking?" is 3.5 minutes into the automated call answering...
Indeed it would be. But that would mean having 2 things to disconnect instead of one. More margin for error. Of course, any diligent spark would...
loz2754
L
