Metal all the way, no brainer | Page 3 | on ElectriciansForums
Discuss Metal all the way, no brainer in the UK Electrical Forum area at ElectriciansForums.net
london
Hi all, just thought i'dd share the picture of the live distribution board we came across this afternoon following a callout
not only was this live when we got there (seems that the fire brigade removed the wrong fuse from the ryefield board) but is a shocking example why every old distribution board should be changed to metal asap
[ElectriciansForums.net] Metal all the way, no brainer
80 year old - nothing wrong with that . was he a sparks ?was his regs current? did he hold testing and inspection cert's ?
was he a member of a scam ? - just saying cause not good to be - ageist . I'm a 103 year old 'battery electrician'b.t.w - U'2s - PP'3s I can change any of them - The worlds my lobster
Anyone watching Counterpart? This looks just like the meltdown that caused a rift in the space-time continuum! I am in the process of replacing a metal CU that is a shining example of why plastic boxes were introduced, I'll post a picture as soon as I can.
speaking as a Kiwi, it beat me why you Brits insist on metal domestic boards. We've been using plastic boards for over 30 years without any significant issues. When I started working in the UK 2008 it felt as though I had dropped back into the dark ages. I reckon plastic is superior and much much easier to use. Metal boards are a pain in the a**e down by the sea
Metal boards are a recent change and most domestic installs used plastic boards for years. The change was due to a response by the regulation makers to a request by the London fire brigade to mitigate the perceived increase in house house fires starting in consumer units.
I much prefer to work with metal boards these days but do agree that a well installed plastic board is no risk whatsoever.
Nothing is infallible. Even a well-installed electrical equipment has failure modes that can generate heat, and where many high-current devices are concentrated together there is an increased probability of enough heat being generated to start a fire. The probability is still low and the risk still small, but where it can be mitigated at modest cost with a genuinely non-combustible board (i.e. not just flame retardant,) and there is no additional risk from using metal, why would you not?
Where a metal board adds the risk of becoming live in a TT install where the Ra is too high to protect the tails, that is a different matter of balancing the two risks.
A few years ago, there was a class action law suit against UKPN because of a number of fires (5) which started in metal cut outs.
The basis of the law suit, was that UKPN had been negligent in not replacing the cut outs in line with their own maintenance schedule.
To my mind that was a mistake.
The y should have based the case simply on the fact that it was UKPN’s equipment which caused fires endangering people and damaging their property.
Now we have to change plastic CUs to metal, because the equipment inside is so poorly designed and constructed that they are now a fire risk.
Rather than tasking the manufacturers with producing safe equipment, change the Regulations so that the consumer has to take measures to safe guard against the dodgy equipment.
It's not just CU's... consider the situation we have regarding fusing down fans. When I designed electronics that were going into machinery I always included local fusing on the boards. I've got a job to do next week where I've installed a bathroom fan and the manufacturer wants both permanent live and switched live fused down, so I've got all the headache of splitting the bathroom lighting just to comply... all for the sake of less than a quid in parts.
It grinds my gears somewhat!
Reply to Metal all the way, no brainer in the UK Electrical Forum area at ElectriciansForums.net
There is no homework, and I'll never see these photo again.
CONCLUSION (Couldn't see how to edit title) It was not belting it down with rain today, so lifted the manhole cover. The pump is about 2 metres...
2 3 4
6K
