Metal cabinet requires polarised plug | on ElectriciansForums
Discuss Metal cabinet requires polarised plug in the UK Electrical Forum area at ElectriciansForums.net
paulmars
central fl
My understanding is that metal cabinet needs to be grounded to the common or neutral 3 wire.
Questions:
When is 3 wire required and when 2?
Why are some plastic cabinets polarized 2 wire or 3 wire?
Why is this metal cabinet space heater that im try to fix, why its 2 wire and neither is common grounded to its metal cabinet?
pictures attached
(Oops! We ran into some problems.
Please enter a message with more than 3 words)
  • [ElectriciansForums.net] Metal cabinet requires polarised plug
Questions:
Paul the best way I can explain polarized is take a lamp with a screw in bulb and the neutral terminates to the part that you screw in the bulb and the hot wire terminates on the tip If you cross the wires then you just made the screw in part hot. It’s all about the manufacturing company and how it’s internally wired. No plastic doesn’t need grounding and metal cabinets does. Since your working on this if it has 2 wires you need to leave it that way.
Reply to Metal cabinet requires polarised plug in the UK Electrical Forum area at ElectriciansForums.net
I think it was too early yes I meant 3 not 2, but great I'll give that a whirl and thanks.
I've seen a few posts here which tend to suggest that wiring in a motorhome (or caravan) wouldn't be subject to normal inspection rules, but even...
