Metal corrugated roof mounting system please!!!!! | on ElectriciansForums
Discuss Metal corrugated roof mounting system please!!!!! in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
saint
West Sussex
Please let me know who makes these and who supplies. I think i have seen a system that screws into the high ridge with rubber epdm under the fixing plate.
thanks guys
What's s the profile - do you mean metak corrugated or trapezoidal? the video is here: Schletter, it;s a good system as it transfers the load to the purlin and not the sheet: Fix-T
SchletterInc's Channel - YouTube
Here's a version for corrugated sheet:
[ElectriciansForums.net] Metal corrugated roof mounting system please!!!!!
and in action: Schletter Installation | FixE on Steel - YouTube
Thanks for the reply but i think you are describing hanger bolt style into rafter or purlin. I was trying to describe a mount that just screws into the metal roof (several fixings needed) with rubber epdm under it.
Anyone else used something like this?
@saint, how big a system? what thickness are the panels? what roof slope?
The Fix-T is fine for a small (10kWp) or so system if you're going bigger, then a very cost effective system is the one we got from Avontech Renewable Solutions used here: (aka PV Heaven !!)
Avontech is a totally seperate company, we have a close business relationship that works to our mutual benefit, we do a LOT of business with them, they look after us well.
Thats the Sen Sol-50 system we considered using it but its end support only which means only some panels can be used and you risk micro cracking in the cells over the longer term, it is a nice system tho very easy. Wind and Sun also do it!
Reply to Metal corrugated roof mounting system please!!!!! in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Thank you for the suggestion!
Hello All, This is Vaithees from India. We are using an IR heater for a vacuum & non-vacuum chamber and got a heater from Chinese company and its...
