C
coxy84
I have 4 independently switched 2000w metal halide fitting on a golf driving range.
They all start up ok but after 2 mins or so they will start cycling on and off randomly!
I'm getting consistent mains voltage (240) into the transformer and consistent voltage out of the transformer (400v ish ).
I have disconnected the capacitors and the problem still remains.
The is no obvious damage to the ballast. With the correct transformed voltage entering it.
The fitting were installed around 8 years ago.
So this leads me to the conclusion that it is the lamps that are failing needing more voltage than the ballast can cope with.
Or the ballast is dying.
Just woundered if any one elese has any other ideas? Before I start wasting money on new parts which are very expensive, ÂŁ145 for a bulb! Ect
