Metal IP rated Adaptable Boxes & Bootlace Ferrules | on ElectriciansForums
Discuss Metal IP rated Adaptable Boxes & Bootlace Ferrules in the Electrical Tools and Products area at ElectriciansForums.net
E
eskimo39
Hi guys, can anyone point me in the right direction? I am struggling to find a metal IP rated Adaptable box approx 5" x 5" x 2". I can find adaptable boxes in metal which would be a struggle to waterproof and I can find the plastic IP rated boxes but no combination of the 2.
Also I am wanting to tidy up my CU installations a bit more, and have been looking at Bootlace Ferrules. Does anyone else use them? Do they make a better termination inside a MCB or am I still better just doubling over the existing core?
Cheers
bootlace ferrules are designed for flexible cables, to stop "hairs". theres no point on using them on solid core cables, even though some people insist on it. As long as your terminations are tight, and you give the a little tug, to ensure so, then thats good!
Are you trying to keep the continuity of the SWA going through the box or just need the metal enclosure for additional mechanical protection. If it's just to keep the continuity going then wiska do earth link bars for their boxes and as said above bootlace ferrules are for tri rated cable and fine flexes not really for solid cores.
WISKA CAS - WISKA INSTALLATION - WISKA COMBI 1210
Reply to Metal IP rated Adaptable Boxes & Bootlace Ferrules in the Electrical Tools and Products area at ElectriciansForums.net
Thanks Brian. I'll keep doing it then, no harm I suppose. I am lucky in that being DIY, I have the luxury of time when it comes to this kind of...
The same socket can be used for different appliances, such as kettles... which will draw more than 5A The size of the cable determines how much...
