dangwynne
I've just started cutting out my walls ready for my house to be rewired. I've marked out the areas for the electric sockets with their base at 450mm however when I've started to drill into the walls I've found a horizontal metal plate about 50mm high about 500mm from the floor which seems to run around every room both down and upstairs. Anyone got any ideas what this is? I'm guessing its maybe housing for wires or pipes. I guess ill need to place my sockets higher up the wall to avoid this as its about an inch into the wall and my socket housing needs to be deeper than that. Also, if it is for electrical wires can I use it or is that now against regs to have the wires running horizontally?
