DurhamSparky
No chaps,
i did promise i would report back on my meteror electrical stuff when i finally powered up and tested..!!
or should that be tested then powered up and tested again for the Reg Bashing amongst us..!
any way!!
the RCBO and the Consumer Units (cheap as chips and tested out as you would expect, never once had an incling that they would catch fire either.)
the cavity boxes i bought!! heap of total rubbish..! fitted 3 out of 5 and had to replace all 3 and just noticed one is broken in the van..!!
extraction fan..! looks cheap feels cheap and WAS cheap.. does job at a price.! nothing spectacular about it! probably get better at wholesalers for similar price
smoke alarm , look and works ok..! no problems..!
service and delivery A+
not a bad company but i probably only ever use them for the Cheap RCBO and CU in future..! (when fitting small Boards 4-6 ways..!!) 17th nearly same price as wholesalers..!! so no point..!!
any way!!
