Meter Change, Minor Works Certificate required? | on ElectriciansForums
Discuss Meter Change, Minor Works Certificate required? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Newmarket, Suffolk
I wonder if I can have any guidance on this issue. In a commercial building we look after they have the old type of meters to check the usage by the occupiers.
We have been instructed to change them to a "Smart" type of meter which will be connected to our BMS to accurately record usage, peaks troughs etc
When we carry out the swapping of these meters do we have to issue a Minor Works Certificate or is this an exemption
It will be a straight swap, the tails were upgraded and renewed last year by a contractor so I know they comply
Might be an idea to check the PSCC at the load side before and after to make sure that you haven't got a bad connection that could cause a problem later. What current rating are the meters, under 100A or the supply for the Shard?
Reply to Meter Change, Minor Works Certificate required? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
If this is a genuine change then throw it back at them, a nicely worded email explaining the additional testing requirements and paperwork charge...
You can obviously put N/A in some of the boxes like the cable size etc because you haven't used any, you can do a loop test at the thermostat and...
