Meter seals? | on ElectriciansForums
Discuss Meter seals? in the Australia area at ElectriciansForums.net
Ross1
Evening guys, who would I need to contact to come out and connect new tails to the DNO 's meter in the Neath valley.
Is it western power?
How much notice do they need?
Does it cost anything?
Cheers
The tails will never be double insulated, none are, they are at best insulated and sheathed.
They may have sufficient insulation to be acceptable even if they are old.
How are you securing safe isolation and complying with statute law if you are rewiring the property and removing an RCD from between the head & meter?
What CU are you fitting, metal clad or plastic?
Ok wrong terminology about the double insulation.
Pulling the DNO fuse for safe isolation.
still need to get rid of very dated rccb, and just wanted for the new install to look neat, ( new tails ) not getting boxed in.
Plastic cu
Just put a call in to Western Power Distribution & they'll tell you all you need to know. Rang them to do a Commercial Metering job just before Christmas & the Engineer was there 2 hours later. Don't know if they're that quick for Domestic though.
Page 3 http://westernpower.co.uk/getdoc/3f...c28f/CNW-Miscellaneous-11-12-WPD-VERSION.aspx
The quoted price of ÂŁ 46 would be enough for me to abstain :rolleyes4:
[ElectriciansForums.net] Meter seals?
Thanks Des, but don't quite understand how they decide which jobs they're going to charge for & which they're not. They reckon 5 Days but for the 1 I was on they were there in 2 Hours flat & did'nt charge the guy anything for it.
I'm not going to enter into any debate or discussion, any of you can say what you like, but to cut the DNO fuse seals and remove, without their express permission is a criminal offence, you do know that don't you?
Well you should if you went to NPTC, SwanColl, or any of the other local colleges in the last 20 years.
Reference to ESQCR, EAWR89, PUWER98 & Criminal Damage.
Reply to Meter seals? in the Australia area at ElectriciansForums.net
Tiling Rates Per Square Meter - How much does tiling cost? Tiling Rates Per Square Meter / Per Day – How much do tilers charge? I know this...
Yeh that’s my thinking. I have to supply the box so can order a bigger 3 phase option to give myself a bit more room
