L
Lynsey
Hi
i've been told 25mm meter tails now have to be blue/blue? yet i can't find a supplier of 25mm blue/blue cable...
does anyone know if you're still allowed to use blue/grey & if you're not, where can I find blue/blue?
Can I ask who told you this.
Most tails now have the outer sheath in grey, but the inner sheath in blue. why is this not acceptable ?
You can get a roll of blue tape for about £1, or for the "top spec" blue heatshrink.
our compliance manager, he states MOCOPA requirements. i had a look on their website & found this:
"A11.3 For single insulated cables, or the insulation of insulated and sheathed cable, the MOCOPA​
Operators, Distribution Businesses and UMetS providers shall use the following colours where they provide new or replacement cables.The insulation of the line conductors of a polyphase phase supply shall be either:a. all brown and marked L1, L2, L3 at both ends, orb. brown, black and grey and marked L1, L2, L3 at both ends.All neutral conductors shall have blue insulation and marked N at both ends.For conductors of less than 500mm in length and clearly visible throughout, marking at one end may be considered acceptable.A11.4 For insulated and sheathed cables the sheath may be the same colour as the insulation (as defined in A11.3). Where the sheath colour is not the same as the insulation, then it should be a colour other than brown, black, grey, blue, yellow, red, green or greenyellow, i.e. not any colour that is currently, or has historically, been used to identify line, neutral or earth conductors.
Well that bit as certainly snookered you. I have to admit I can't remember ever seeing tails blue/blue
If they are short lengths these people do 30mm OD to custom length, but I bet not cheap
http://www.cablecraft.co.uk/ProductGrp/0007000e0011
Well as MOCOPA are meter fitters, and I personally have only ever seen gray/blue tails, they have either never issued blue/blue to their guys, or every meter is installed against their recommendations
How typical of bureaucratic regulators to insist, by regulation, on using a product which does not exist.
As Mark Burgess said, blue shrink-fit might be the way to go. ‘Mister shrink’ and others on EBay have a good selection at fair prices, in mixed bags, and often the bigger stuff in single colours sold by the metre.
BTW, I use an EBay chef's blowtorch to shrink it. A brilliant piece of kit!
I too have seen these installed in small ind unit by Scottish power, had to look twice because I initially thought they had installed single insulated tails! :-)
We do a lot of domestic new build and seen this quite regular for the past few years
By the sounds it only applies to the meter fitters/distribution and not ourselves as electricians following bs7671
A reason possibly maybe because they will now train anyone to fit meters, so making sure colours are identified better/easier ...basically dumbing it down
Me too, have seen them recently down here - Br/Br and Blu/Blu. But then I've also had DNO guys scrounging bits of 'grey' 25mm off me too when they've not had on the van, so can't be THAT big a deal.
get some letter tape like the board uses you know the stuff comes with either l1 l2 l3 or neutral on it then if boss says anything tell him it,s in case people don,t understand what the colours mean.Anyway thought you had to be a competant person to work on wiring these days so arguement 2 is if they cant understand the obvious sounds like they aren,t competant,or does your boss not live in our world?you could always tell him it,s 5 times more expensive,he,d probably go off the idea then.
I bought some 25mm tails a few months ago and when they came they were blue/blue and brown/brown, I think that I got them from Fastlec, if I remember correctly (I can check later if that helps).
They were Fastlec part no.s 6181Y25SPLITBLU & 6181Y25SPLITBRN. The picture on their website shows grey sheaths but when I ordered from them the cable they delivered had blue or brown sheaths (the description on their website doesn't actually specify the sheath colour). Might be worth phoning and asking them about it if you really must have coloured sheaths.
Hi,
I work at Fastlec and we usually have both grey outer or coloured outer. Occasionally, the cable manufacturers themselves run out of the coloured outer (which is very popular with our local contractors). Give us a call on 01903 730050 before you buy and we can check the current state of play with stock for you.
Best Regards
Robin
Fastlec
I see a lot of older tails around here with no sheath at all, just red and blue insulation. Did sheathing / putting in conduit not used to be a requirement? Off topic, I know.
Hi
Double insulated doesn't matter about the colour of outer sheath
i always use a bt of coloured heat shrink on my tails so identified electricity suppliers lable them L1 1 L2 L3 and N , and always use brown for live blue for neutral and never 2 blues with heat shrink on
We did a rewire about two years ago for a local client who owns a property in Brighton and that had blue and brown double insulated tails from the meter , and the local CEF branch down there only had them in stock .
Have seen them starting to appear around Bucks recently as well now .
At the end of the day does it matter if the outer sheath is Sky Blue Pink with Yellow Dots.
Just so long as the inner cores are correctly identified and terminated.
^^^ Has anybody bothered to read this properly ?
It states outer sheathing may be the same colour as the insulation , not must.
Therefore not compulsory.
Pfft , thats jobsworths for you.
Think its the last bit where it says that if the sheath is not the same colour as the insulation then it should be a colour other than brown black grey blue yellow red green or green/yellow that started it off.
My bad lol.
I don't really think the outer sheath colour matters,
but the ones we (sometimes)use are made by copper cable company, however even being a dno we ususally fit grey outer sheaths with L1,L2,L3 or N labels as applicable
Meter Tails - Blue Sheath?
Lynsey,
Thomas123,
