G
GEOFFERS66
Hi Folks just started working on domestic after working on big stuff with the MOD for a long time & a problem has cropped up. The supplier has moved the meter to outside of the building requiring cable updates (uninsulated neutral at the moment) leaving an approx cable run distance of 15 to 18 metres to the CU. I know there are issues of using meter tails of over 3M & the only way I can get to the meter is in the ceiling void & through wall, I used to use swa cable to get around most problems but that seems extreme in this situation, the only other way obviously is to reposition the cu & rewire. Any Ideas?
Cheers
Geoff
Cheers
Geoff
