A
antix_v2
Hi people,
I'm sure there is one 'simple answer' to this but between those on site we now have a multitude of opinions.... So, thouight I'd ask people with a bit more experience what the best way of doing this is. The supply company has changed it's mind on the position for the meter for a few reasons which has meant we're having to change our plan.
(See diagram)
What's the best way of routing the meter tails. The consumer unit sits on the inside wall, around the corner from the proposed site of the meter. The wall construction is plasterboard, 100mm celotex insulation, ply board, then over-clad in timber (barn conversion...). The meter sits a little lower than the CU - i.e. the cables needs to go around and down.
So how do we comply with regs, stay safe and make it neat.
p.s. the internal area here is all out of site as it's in a thin utility room and has doors across it to make a storage cupboard. So we can be less concerned with the look so to speak.
Thanks in advance guru-sparky's!
(See diagram)
