Meter Tails | on ElectriciansForums
Discuss Meter Tails in the UK Electrical Forum area at ElectriciansForums.net
B
beanocur
Hi. I've recently moved into new house. The meter box and consumer unit are installed in cupboard underneath the stairs, however they are approx. 1.5m apart and the tails are surface mounted. Should they be encased in trunking so as to protect them from damage. Thanks
No they don't have to be encased in trunking but should be adequately supported. Is this a new build with consumer unit under the stairs?
The tails are insulated and sheathed and are considered adequate for the use you describe as long as they are supported adequately
Plastic trunking would not provide much in the way of mechanical protection
Many are done like this, but it doesn't make it attractive. The back wall equipment could be "put in a cupboard" perhaps, which at least will stop all your kit being thrown at it.
Reply to Meter Tails in the UK Electrical Forum area at ElectriciansForums.net
Thanks for the replies, I appreciate it.
Yes the first bit is just standard wiring, TNS lead cable into cut-out, cut-out to meter, meter to DP isolator, top of isolator is sealed as per...
