meter tails | on ElectriciansForums
Discuss meter tails in the UK Electrical Forum area at ElectriciansForums.net
B
Buzz-light-bulb
Hi all
I'm doing an eicr and I've come across 25mm consumer unit tails connector blocked on to 16mm tails going into meter what code would you recommend
If the service fuse protecting the 16mm tails is adequate for the tail size and the connection block is the correct rating & secure then for me there would be no no code. (Makes no odds about the 25mm, its the 16mm thats the limiting factor)
If you've only got a 40A connector then I would guess thats not up to the potential load and needs replacing ..... but as above pic & more info needed to really pass judgment!!
Reply to meter tails in the UK Electrical Forum area at ElectriciansForums.net
Thanks for the replies, I appreciate it.
