Metering info | on ElectriciansForums
Discuss Metering info in the Australia area at ElectriciansForums.net
London
Hi all,
Having a blank moment and wondered if anyone can help!
I have been asked to move a meter from the mains head to about 20m away, i know i cant touch the meter but i need to install the cable to an isolator.
Is there a maximum distance EDF will allow from the mains head?
Cheers :D
Not sure what EDF request but most DNO insist that if you extend tails over 3 metres then you should run in either SWA or Concentric.
Also that there should be a protection device installed to protect the cable. If the run is surface then you can use a standard switch fuse, if the cable falls under regs 522.6.5 or 522.6.6 then it has to be RCD or RCBO protected.
Hi all,
Cheers :D
Just wondering Matty who asked you this? I've had many jobs moving the CU but not sure a DNO will want it's meter 20meters from the header
Reply to Metering info in the Australia area at ElectriciansForums.net
I think it's more towards what the future brings with them and their ability to measure true power. Half remember a video from bigclivedotcom that...
If you have an EV the EV charger will also log the supply Are there current transformers on each phase?
