metering | on ElectriciansForums
Discuss metering in the UK Electrical Forum area at ElectriciansForums.net
i=p/u
Northern Ireland
if there is a 3 phase suplply but only single phase meter, does i cosst much for 3 phase meter to be installed..?? do all charge what they want? do i have options?
No idea. But a quick call to the supplier of the premises should get you the info. I usually leave this to the account holder to do. If it's a commercial property just make sure you have your DB mounted with the tails ready to go into the meter.
its the way thy have installed it there is a 3 phase head their with only one fuse in holder then onto single phase meter , then board..
i had taken fuse carriers out and measure voltage and 3 phase defo in there
Have a similar set up in a customers house at the mo. Historically house had 3 phase supply for some unknown reason. DNO have relocated 3 phase head, currently only using a single phase - 100A fuse. Transformer has to be upgraded for 3 phase they say.
Reply to metering in the UK Electrical Forum area at ElectriciansForums.net
That looks like a Metrel display (I have one), they have a permanent 3 wire display that measures the three combinations so I would say that’s a...
Thank you to littlespark for clarifying my mumbo jumbo. Just to say that being on a dual tariff means you will typically pay more for electricity...
