G
greeny
Hi all, I am pleased to be onboard with you all and looking forward to joining in with the forum activities.
My reason for my new interest in this site today is this.
I have a "Metrel Easitest" multifunction test set and ever since I had it I have never trusted the trip lock readings of Zs. For instance on an expected Zs of say 0.4 ohm I get readings variant from 0.01 to 1.9 ohm.
I have done a trial test with 20 readings, it took a long time and I then obtained an average which is very close to expected results but why should this be. Is this normal for this test set/other test sets, or a fault.
With the 17th edition trip lock is even more necessary, so should I ignore the trip lock facility and just add ,measured Ze to R1+R2, previously measured on continuity, and record the Zs result that way.
Help please
Help please
