dave30
hello i found your post and seen you had a metrel mi3000 and was wondering if i could as you to help me with a few test procedures
having difficulty used kewteck on my course and now confused with different tester have looked at manual but just want to be sure
could please run through were you connect the leads on this tester dewring tests and what setting to use
1st Ze reading
2nd Zs at db
3rd the two ipf test for prospective fault current earth and neutral
this is how i think ts done
1st test Ze main earth lead out met . green lead to main earth lead line lead to line in and neutral lead to neutral in press test z loop setting
2nd test Zs at db main earth lead back to met green lead to met line lead to line in and neutral lead to neutral in press test z loop setting
3rd ipf [ i think ] green lead to met line lead to line in neutral lead to neutral in press test z line setting
4th ipf green and blue lead combined in neutral in and line lead to line in process test z line setting
i no im asking allot im learning on my own trying to learn this stuff could you please help
thanks david
1st Ze reading
2nd Zs at db
thanks david
