metrel mi3125 | on ElectriciansForums
Discuss metrel mi3125 in the Electrical Tools and Products area at ElectriciansForums.net
saracen
anybody advise me on this particular test kit as I'm thinking of buying one
Hi Saracen,
There are two different models which look identical. There is a Metrel MI3125 Eurotest Combo Lite, and the Metrel MI3125B Eurotest Combo Pro.
The pro model offers the following over the standard model:
1) Type B DC current / high frequency AC current RCD's test option,
2) Earth resistivity test (with use of the additional Metrel earth resistivity kit),
3) The ability to store and download test results into the Eurolink Pro software included.
The Metrel MI3125B Combo Pro is also one of a few testers within the Metrel range which you can connect the Metrel Easi Switch Adaptor to. This adaptor essentially allows you to connect all six conductors of a ring final circuit to your tester, which in return will display all of the 'end to end' resistance values of line, neutral and CPC. The tester will also auto calculate your R1+R2 value by linking the Line and CPC conductors via a relay within the unit.
I hope this gives you some information and an insight in to which tester that will suit your application :smile5:
We carry both units in stock and honour you a 5% discount as you are a member of the forum.
test-meter
I've got the 3125b and find it great so far. Had it a year now with no problems . Rechargeable batteries, nice handy size and the magnetic back is like an extra pair of hands when taking readings at dbs. (unless they're plastic of course)
Reply to metrel mi3125 in the Electrical Tools and Products area at ElectriciansForums.net
I always find it a bit strange that people will buy test kit by brand name rather than what it will actually do and it appears that some brands...
Hi I thought it was with amendment 2? Haven’t double checked.
