Metrel multifuction tester | on ElectriciansForums
Discuss Metrel multifuction tester in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I
iconnect
I have a metrel tester and if the earth loop readings in less than 0.50 ohm it just tells you that and does not give you the correct reading can I change this ? Please help as its doing my head in. Thanks Kelvin
Just doing PV systems at the moment but do all domestic I had what I thought was same tester and that gave me a reading I just don't get why it will not take the trip lock of there you go
Reply to Metrel multifuction tester in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Having some issues with my companys fluke 1662/1663 tester. Zeroing 2 leads for continuity test we get the value 0.08 which is expected. The issue...
"When stoned..." Brilliant!
