metrel tester | on ElectriciansForums
Discuss metrel tester in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Farmelectrics
Wirral
fadeing disply got a metrel 31000 replaced re chargeable batterys and still the same problem only got calibrated recently any ideas
Odd one, have you tried operating the backlit display and seeing if the screen blanks, this would indicate (since the batteries should be OK) a loose connection to the screen supply, unfortunately not sure how to fix such a fault. I assume the rest of the meter functions correctly?
Could you video it doing thing, from powering on, maybe time. And post it some were so we can see
I think might of seen some thing like what you speak of but on a calculator. But I think that was water damage
Reply to metrel tester in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
"When stoned..." Brilliant!
Having some issues with my companys fluke 1662/1663 tester. Zeroing 2 leads for continuity test we get the value 0.08 which is expected. The issue...
