Guest viewing limit reached
davelerave
anyone got advice on domestic installations where the grid is already in place
(usually we're in before the grid)
regarding cable runs and cable support
-handiest install methods?
-because of the price of copper it's not practical to bunch cables in main runs
-is EMI a big issue with network cables if they're draped on the grid?
thanks
All the cables should be supported , cable band, cable ties , lops of twin skin, but keep them off the grid, ( Im assuming it hasent been boarded ! )
usually we do chalk lines for mains and data 'main runs' before grid goes in
and fix the clam type swa glands to underside of hollowcore
that method of wiring is too expensive now -as the cable runs are longer than necessary
'the ceiling grid is neither exposed nor extraneous in normal circumstances so shouldn't be earthed or bonded'-is my understanding
always was concerned about the ceiling grid inadvertently becoming live -what do you guys think?
If you were to properly bond a ceiling grid you'd spend more on that than the installation!
true-so don't do anything with the grid then :o
as it's neither exposed nor extraneous
some guys seem to routinely earth them as a precaution
If it's not an exposed or extraneous conductive part, then by bonding it could potentially make the grid LIVE during a fault, so routine bonding becasue it's metal is not advised really.
Always test first, don't assume anything when it comes to ''commercial grid ceiling installations''. During the installation of these grid hangers, it is more than possible to make contact with the slab re-bar, thus making the ceiling grid an extraneous conductive part. Had that happen on projects on more than just a few occasions!!!
these are concealed domestic ceiling grids
the commercial T bar grids are different afaik
you couldn't effectively bond the commercial grids i would think because of poor continuity
mf ceiling grids and wiring
davelerave,
davelerave,
