Darkwood
Had the local wholesalers premoting his varied range of Wago push fit type connection blocks when he showed me one that had me thinking that to use it correctly you would contravene the regs... your thoughts...
What he showed me was a connector for downlight where its got entry points on one side for solid or normal stranded cables and then on the other side of same connector it has a entry designed to clamp fine wire like flexes etc which you normally shouldn't use with these type of connectors ...all sounds super duper BUT!!! heres the thing the reg's does state that fine wire cables should always be crimped with the appropriate crimp or ferel before termination thus the design features of said connector seem to be made to fulfil a issue that shouldn't exist if the electrician was doing his job correctly in the first place by crimping the cable.
