F
fishy pirate
Hi fellow sparkies,good to join you.About to rewire a ground floor flat,the tails are fed from a kmf switch fused down to 60 amp external to the flat in a mains cupboard which supplies all the flats.My question is what are the regs on keeping the mi mains cable to the flat.I 'm thinking l'll have to replace it with 16 or 25 mm swa(about a 12 m run),with separate 16 mm earth,but its a bit of a job,any input would be grateful cheers
My house has a micc mains cable (about 10mm) and the lights are stil wired in micc as the ends are fine and both circuits IR tests were clear good electrical and mechanical sound (14th edition) no seperate earth.
Nothing wrong with a bit a micc
cheers for the input,not sure what size it is,l'd say they'll probably 10 mm,but must of been installed to cope with a 60 amp load,i just needed a bit of positive feedback(haven't touched mi since i was an apprentice) so if it tests out fine l'll keep them...still think l should put in a 16 mm earth though for 17th
Plus, to make it easier to terminate the MI, connect them up to a DP service block and run your new tails from there.
mi mains tails
fishy pirate,
Spudnik,
