I've been given a job to rewire an upstairs flat and change the CU. I had a quick look around and everything is pretty straight forward except for the CU.
The existing CU is located in the small entry hall way at the bottom of the stairs leading up to the flat. It is mounted at high level opposite the front door. The meter is located in an external cupboard next to the front door. 16mm tails come from the meter into a henley block with MICC from the henley block to the CU.
I'm struggling to think of a solution to replace the MICC. Help. Please. Pretty Please.
