Micc | on ElectriciansForums
Discuss Micc in the UK Electrical Forum area at ElectriciansForums.net
Nolnoc
Hi guys
I've a small pyro job coming up and I haven't done any since my apprenticeship(a long time ago).I have been searching you tube looking for a video with no success.Anyone know of any online. I'm sure I'll be ok with it just a kind of refresher.
Cheers
practice on a bit of scrap before stripping the ends you don't want to damage. sure it will come back to you after a couple of bodges on scrap ends.
Good advise off tel
If you have done it before,it will be like riding a bike,you knew it,so you will know it
My question is
Do you still have the tools ?
[ElectriciansForums.net] Micc
Just remember the important bits, no air pockets when filling pot, dont touch the sealant and meggar regular when making off Ohh! and dont forget to discharge the capacitance before touching again :wink_smile:
Had to laugh reading through the link got to page 6 never used a Pyro Wench before
In the past I have used a small copper pipe cutter for ringing the Pyro probably cheaper than the Pyro ringer if it is a one off job not got an alternative for reliably crimping the pot though
"Pyro wench" ?? Had a girlfriend like that, difficult to strip, not the best to look at but once you put the work in worth the effort.:shocked:
That's a very good instruction manual on how to terminate MI.- better than the old CITB sheets. However, I'm afraid I do not agree with their test methods. Do not make off both ends before testing. One end at a time....
Why not, just don't put the compound in the second end before you do the tests
Wench is a new one on me too. Also had a special pot sealing tool (still got it somewhere). Like a pair of mole grips. Quick once you got used to it, got gunged up with compound but no real problems. No sign of it in the tools list.
Reply to Micc in the UK Electrical Forum area at ElectriciansForums.net
If the main switch is on when testing global IR then the neutral and earth will likely give a very low reading. Not that anyone would...
loz2754
L
Best Electrical Courses I endeavour to create a "best electrical courses" thread for 2025 (so training courses that did well during 2024 are the...
