Micro-generation/smart meters compatibility issues | on ElectriciansForums
Discuss Micro-generation/smart meters compatibility issues in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
SolarCity
We went to see a potential customer earlier in the week who had had smart meters fitted recently. He told me that the engineer warned him about problems in the future if a PV system was installed and that it probably wouldn't be compatible with the meters he had fitted.
Has anyone heard of this before?
A proper smart meter that can handle and record energy flow in both directions? In which case, I thought that part of the point of them was they could handle pv.
Or
What British Gas et al call a smart meter, which is little more than an energy monitor? In which case I could see it going belly up depending on where their current clamp is fitted in relation to the pv.
The only issue I have heard of is early SmartMeters that could not register export. But that is just the same as not having an export meter fitted so 50% deeming applies.
Reply to Micro-generation/smart meters compatibility issues in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
It sounds like the original meter was reading incorrectly and octopus aren't keen to admit this as they would probably have to refund you. I...
davesparks
