Microve Sensor question | on ElectriciansForums
Discuss Microve Sensor question in the UK Electrical Forum area at ElectriciansForums.net
The ones I have had dealings (early 90's) with had a sensitivity switch (h,m&l)inside plus a potentiometer for fine tuning for that very same purpose. I don't think these could be masked as such.
Hello and thanks,I've tried cranking it down to MIN but then the range is poor and defeats the object.
It is mounted outside, location was limited and passing buses set it off.
It was a freeby.....at my age I should have known better!!!
What kind of microwave sensor do you have and wha's the application?
Thanks for the interest,I'ts a Knightsbridge/ML Accessories unit from my usual indy lighting man (don't laugh all the
bigboys in Bristol use him!)
I,ve put it in a Fern Howard 28W adapted to run an LED Retro-Fit in my back garden in an attempt to dissuade the
local NEDS from visiting.Trouble is it picks up all sorts of false triggers due to its inherent efficiency.
Trouble is I'm an old school 3/4" conduit/7.029/ 268 PYRO Fart and I won't let It best me!!!!
- - - Updated - - -
Reply to Microve Sensor question in the UK Electrical Forum area at ElectriciansForums.net
CIS registration is pretty simple. Give the CIS helpline a call and request to be activated as a cis subcontractor. Not contractor though, there...
I can imagine it just disappearing (loudly) under short circuit conditions, then the resulting blast/plasma etc. casing the busbars to flash over...
