Microwave above sink | on ElectriciansForums
Discuss Microwave above sink in the UK Electrical Forum area at ElectriciansForums.net
daveb
Aberdeenshire
Hi all,
Was out looking at a job today in a clients office, and have been asked to quote for installing an additional socket for a microwave.
They have installed a shelf directly above the kitchen sink and have placed a microwave on it - present cord is stretched out across to a worktop socket.
Anyway, I trying to find the regulation to refer to that prevents applicances and certainly sockets above sink areas. Having searched the on site guide, all i can see is recommended "horizontal" distance is 300mm. Even though the shelf is secure, I am fairly sure that this is against regulations and would like to quote a regulation to him rather than just saying it can't be done.
Thanks in advance!
I can't see an issue, but I wouldn't be happy to leave it like that. Is there no chance of moving it over the draining board at all?
I don't see an issue with this. You often come across plugs in the under sink cupboard which could potentially cause more issues than a socket sited 700mm above the sink with a shelf in between it.
As far as i'm aware no regulation stopping the under sink cupboard socket and so no regulation stopping one 700mm above...
it's all nanny electrics. one day they'll have us fitting them new-fangled earth leakage trips to circuits in case some dipstick shoves his fingers in a socket outlet.
Electrically I don't see a problem. I'd avoid mounting cooking equipment above chest height for an average person because if you can't see clearly into the microwave there's a higher risk of burns when removing cooked food.
Its one of those things that just doesn't look right but there's no logical defense for that feeling.
I had the same with wall brackets for heat pumps/AC it just don't feel right having that weight hanging of the side of a building, vibrating away, above peoples heads. But how many failures do we hear of?
Still don't feel right though.
Reply to Microwave above sink in the UK Electrical Forum area at ElectriciansForums.net
