Microwave Leakage Testing | on ElectriciansForums
Discuss Microwave Leakage Testing in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
P
PAT ukLtd
Hi, I'm sorry I know this has been mentioned before but unable to find the thread. Looking to purchase a Microwave Leakage tester and interested in models you can recommend.Also wondered about fee's to the testing.
Cheers!
I use a CEM DT-2G Microwave tester available on Ebay for about £27 ish. Manufaturer states does NOT need Calibrating.
As to fees
The way I see it you dont charge more for doing a class I appliance than a class II even though it takes more time so why charge extra for a microwave safety check,
I do the microwave safety checks, ie Leakage & interlock checks free, its an added incentive.
If they want microwave power checks done that is not a required safety check so I do charge extra for that.
High, as an ex Leigh inhabitant, I thought I ought to suggest:
1) Buy a suitable optical thermometer - Maplin have a good range, mine was £10.00
2) Buy a small tupperware type container with a lid,
3) Expand your test so you have a leakage test, (ensure you include the door release mechanism) and by checking the temperature increase in a fixed volume of water over a set time of operation include a power usage check ( i.e. indicates will cook properly). Buy specific microwave testing labels and always quote the service as a specific test that you will carry out on all microwaves. Charge £5 - £10 per microwave.
4) If you get a leakage failure, give the door seal a good wipe then retest.
Heres my thinking on the micro power issue if its low itsgoing to take a wee bit longer to irradiate the food if its high the punters gonna complain the the foods wasted and bucket the machine and spend £30 at asda (other supermarkets are available :) )
i have never spent additional time on this as i have no expertise in adjusting the power ouput of a microwave oven
I do my visual class one interlock and microwave leakage tests always remembering to put a cup of water or something in the thing ..If its warm when i am done the functionality checks complete.
I charge microwaves at the same rate as regular class 1 tests, additional time you say ,well usually its easier to get at the plug etc on these than many other appliances.
Reply to Microwave Leakage Testing in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
It might be worth asking the customer to turn the oven on 45min before you arrive. then do an IR test on the oven from the isolator with the oven...
Check the clearance between the back panel and/or terminal cover that you've removed. Look for small burn marks.
