Military Spec Crimping tools | on ElectriciansForums
Discuss Military Spec Crimping tools in the Electrical Tools and Products area at ElectriciansForums.net
edexlab
Uk
I'm looking for some Military spec ratchet crimp tools for Insulated Yellow/Black , Red, Blue and non insulated terminal crimps, I'm not sure of manufacturers names as yet , but can anyone suggest a UK supplier which is reasonable as I know these are expensive!
A ÂŁ20 one will fall apart once it has taken a beating, a ÂŁ100 jobbie will do the job nicely for many years, a ÂŁ400 piece of kit will do the job just as well as a ÂŁ100 one, only the company that sticks their brand on it will have mugged you off for ÂŁ300 coz they can get away with it :D
These are the ones I use for insulated baby crimps:
[ElectriciansForums.net] Military Spec Crimping tools
I paid just shy of ÂŁ100 for them but boy were they worth it!
Just a cheapo ÂŁ65 made in china jobbie. Does the job fine, I've only worn one set of seals out in two years and it came with a spare set. I'll pay ÂŁ65 ten times over though and still have spent ÂŁ1000 under what a top of the range set would cost. Compared to my first set of ÂŁ20 ratchets that only lasted 6 months, I'd say I'm on the right track :)
The real difference in pliers is if you go down the route of crimping solid core. I have an ÂŁ800 set which a German installation engineer left on a commissioning job about 20 years ago and didn't want back. They crimp anything, whereas my workmate at the time had a ÂŁ30 pair and it wouldn't work at all on solid.
Disclaimer....I hate crimping solid core, and do not wish to reopen this can of worms ;)
Depends on what these ''military spec crimps'' are going to be used for...
Any internal equipment wiring for the military, will need certified calibrated crimp tools to be used!!
Reply to Military Spec Crimping tools in the Electrical Tools and Products area at ElectriciansForums.net
N
That's the problem - they're all pretty much clones of one another. There'll be considerable differences in quality, but nothing that stands out...
nicebutdim
N
This contactor you suggested unfortunately only has two NO switches rather than 1 NC and 1 NO required for the CR3 current sensing bypass...
