Mini Heat Shrink Gas Torch | on ElectriciansForums
Discuss Mini Heat Shrink Gas Torch in the Electrical Tools and Products area at ElectriciansForums.net
Midwest
Nearly Esteemed
Oxfordshire
A while back I bought one of these little torches; New Mini Gas Torch Shrink Tubing Heat Gun Tool W37 | eBay. Not from this seller I must add. Apparently, you just insert a click type cigarette lighter. But I can't for the life of me to get it to work. Anyone know how or has one?
I used one similar , just fill the refillable cartridge with lighter fuel, refit it. The one I used had a little locking device and auto ignition.
Must admit refillable cartridge looked like a throw away lighter but had no wheel or flint.
I bought one of these too and had exactly the same problem - until I realised I had to put gas in it !!!
It is just a disposable lighter with the flint mechanism removed, and is refillable from a canister that can be bought from a Pound Shop, OR you can simply put a full disposable lighter into it - with the flint mechanism - and it will work.
You have no idea how happy (delighted even) I was to read your post as I was beginning to feel like the most stupid person on God's earth. Now I have company !!
Do you remember when you were a kid and you used to take the cover off a lighter, turn it up to max, then lift the lever to go back and turn it up some more, then put it back together to make a mini flamethrower?
I've heard you have to do that, but leave the cover off.
No ..... when I was a kid, we only had matches and candles to play with. :(
Mine doesn't have refillable cartridge, I've tried ripping the head off a lighter, but it just floats arond inside the case.
This 'refillable cartridge' looks just like a disposable lighter, but there'll be a little brass valve at the bottom where you can refill it.
Hi Midwest check out this video I know its a different make but it may be how yours works.
check out 1min-25 sec
Soto Pocket Torch - YouTube
Thanks Silverfox, followed the video putting in my 'zippo' lighter, but it still doesn't work. Guess I bought a duff one!
Infact, just rechecking the vid, my light seems to almost flush with the holder, not slightly proud. Perhaps I could put some packing in there. Can anyone give my measurments on how far the lighter sticks out of the holder?
Reply to Mini Heat Shrink Gas Torch in the Electrical Tools and Products area at ElectriciansForums.net
