Minimum separation distance between LV underground cable and Water service | on ElectriciansForums
Discuss Minimum separation distance between LV underground cable and Water service in the UK Electrical Forum area at ElectriciansForums.net
L
laxmi
Hi,
I have noticed the following item in a new construction site. Could anyone can give me further suggestion, please.
1. What is the minimum separation distance between LV underground cable and water pipes (Cold water)? This is for new underground cable lying. Water pipe is to run parallel with LV underground cable. Currently, the underground cable is separated by 200 mm. No cable termination has been made yet.
2. Can we install Distribution Board (3phase) and water pipe (Cold water) in a same plant room. The plant room is 2m x 3m x 3m. This is again new installation. On above construction, LV cable and Water Pipe is located in a same plant room.
Could I ask any references for above queries, please.
Your advice on this matter will be much appreciated.
Lax
Reply to Minimum separation distance between LV underground cable and Water service in the UK Electrical Forum area at ElectriciansForums.net
Recommended Sponsor News
thanks for the clarification. ( also thanks to Dan. ).
More info on link below http://sbsc.uk.net/
9K
Happy Friday Everyone! Subscribe for more jokes direct to your mailbox or send us your own jokes to be in with a chance of featuring, by clicking...
6K
