Minor Works and Meter Tails | on ElectriciansForums
Discuss Minor Works and Meter Tails in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Djlelectrical
When installing lights would you change meter tails from 16mm to 25mm. Customer doesn't want to pay for upgrade main service fuse is 60a
Even if its not as per the regs ?? they recommend 25mm
I'd more more interested in making sure the earthing/bonding is correct.
What's the CCC of 16mm tails? ;)
If I was replacing a CU then perhaps you would but I don't see the point to be honest.
If the customer doesn't want to pay then why do it?
Bonding is fine and up to date, The 16mm tails will carry roughly 85 amp so im not bothered about that.. its a case of weather its acceptable to issue MWC if the tails are not as per the regs
You wouldn't find me changing them, you've just proved yourself that they do not need to be. 16mm tails rated to 85A protected with 60A device, where's the issue?
What earthing system is the installation using?
Its a TNCS, just beating myself up with the regs as they state minimum 25mm
As I keep seeing posted recently, the Regs are Guidance Notes NOT LAW. In this situation you can safely justify why they do not need to be replaced especially as you are only doing a Minor Works. CU change? Fair enough but the customer has already stated that they do not want to pay for it.
Reply to Minor Works and Meter Tails in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
In the 80's I was taught that with PME earthing arrangements we used 16mm for the main earthing conductor, some went a bit crazy and were bonding...
