minor works cert. info needed | on ElectriciansForums
Discuss minor works cert. info needed in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
J
jutty
for my part p inspection i have changed a battern holder in a bathroom to a drum fitting...but on that circuit is 6x12v down lighters, do you think i can get away with not IR testing due to the trannys on the circuit if i write it on the minor works cert..
the property has no main water bond or gas bond, i have wrote on the cert. no main bond to water and gas...thats all i can do really isn't it??
:eek: no water or gas main bonds:eek: good luck with your inspection my friend i think you will need it.:eek:
You can change a fitting without informing anyone, you can use wet string to wire, no law against. You can do what you want. Right now in this country scare tactics are used to give work to council workers, most council 'inspectors' need a job, because a normal firm would not give them one.
You are correct in advising, no bonding thus qualifying your understanding of normal practice.
paul m
There is no law states water/gas has to be bonded, especially if overhead feed or plastic water input, or 17th edition.
While sometimes advisory, there is no statute law. Otherwise the courts would be full.
paul m
There is no law states water/gas has to be bonded, especially if overhead feed or plastic water input, or 17th edition[/quote] what planet are you on,we are not talking about law we are talking about BS7671 which i know is non statutary but can still be used against you in a court,you are supposed to check earthing before doing any work and if not up to scratch you are supposed to inform the client,i know from past experience when he takes his nic man to this house for his assesment the first thing he will want to see is earth bonding to gas and water,and where did you get plastic from trhe original post never mentioned plastic.
Well your going to fail on two counts if its a NICEIC assessment
No equipotential bonding & not udertaking correct test/certification.
Another point if you have no equipotential bonding you'll be needing supplimentary bonding in the bathroom.
To IR test circuit at cu join line & neutral & test to earth & test at 500v or do it properly & remove the trannies & lamps.
It's not all you can do & you know it...............install the bonds at a price, if the customer declines the bonding to be done then walk.
As for the law thing wattsup ..... my understanding is that part P is the legal document along with electricity at work regulations & I think you'll find that it states in the part P doc that you as the installer must ensure your work complies with BS7671.
As paulm said if it went to court you'd be bashed with EAWR & part P & 7671 would be used as a refrence for compliance.
Take a look at 544.1.2 & take in the bit about insulating section or insert.
your theory might be ok if all the pipework is in hep/plastic.
i will take him to another job not really a problem, just that was close to my home!!
to get bonds to gas and water would be a nightmare and they won't have it done to much damage, there attitude is everything works and there isn't a problem and the cost obviously!!!!!!!!!!!
and the 6 down lighters are in so tight the chances are removing them all will damage the plasterd ceiling!!
i thought advising the client would be sufficient!!!!
hi im tryin to get me self ready for my assesment with the nic on the green minor works cery where there is a box it says rcd BSEN my rcd is a 4293 im not sure wot type it is tho i think its a type B is this right thnks
that,s priceless i will just take him to another job if you were not so dangerous
that would be funny.
the equipotencial bonding should have been brought the customers attention
and done first.
if they are not willing to have it done you should not have done the lights
you are now responsible for an unsafe install
i suspect the original post was a wind up?! Late april fool? Daz
Reply to minor works cert. info needed in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
If this is a genuine change then throw it back at them, a nicely worded email explaining the additional testing requirements and paperwork charge...
4-5 hours for 150? no chance, this is 2024, 150 for 2 hours maybe, that said an hour seems pretty quick, not sure he did the job right
