Minor works certificate - Ze Test | on ElectriciansForums
Guest viewing is limited
Discuss Minor works certificate - Ze Test in the UK Electrical Forum area at ElectriciansForums.net
tomodo
United Kingdom
Hi on the minor works certificate it asks for Ze, so any time i install an addition to a circuit lets say, i then have to isolate the whole system disconnect the main earth and test each time? Is there anything that permits the test be completed without having to disconnect main earth? Thanks
Reply to Minor works certificate - Ze Test in the UK Electrical Forum area at ElectriciansForums.net
You can obviously put N/A in some of the boxes like the cable size etc because you haven't used any, you can do a loop test at the thermostat and...
If this is a genuine change then throw it back at them, a nicely worded email explaining the additional testing requirements and paperwork charge...
