Minor works Certificate | on ElectriciansForums
Discuss Minor works Certificate in the UK Electrical Forum area at ElectriciansForums.net
P
P=I2R
Hello,
I've been asked to install an extra socket into a kitchen, After taking a look at the job it would be easier to run a supply directly from the CU rather than spur off an existing socket There is a spare 16A RCBO available . Which certificate would i have to provide for this installation a Minor works or a complete electrical installation certificate for the extra socket
Cheers
Reply to Minor works Certificate in the UK Electrical Forum area at ElectriciansForums.net
You can obviously put N/A in some of the boxes like the cable size etc because you haven't used any, you can do a loop test at the thermostat and...
It applies to commercial if it shares the same supply as a dwelling.
