Minor works certs testing | on ElectriciansForums
Discuss Minor works certs testing in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
A
ab1978
hi all
when you do a job that only requires a minor works certificate and you need r1+r2 reading say for a extra socket, do you just test the new cable going to the new socket for r1+r2 or go round the ring?
with the first one could'nt you just do an earth loop test at the socket your coming off to make sure there is an earth path.
hi all
When you add a new socket you have to do a r1+ r2 for the whole circuit as this is the resistance if a fault accured.............
Reply to Minor works certs testing in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
If this is a genuine change then throw it back at them, a nicely worded email explaining the additional testing requirements and paperwork charge...
Interesting question & always gonna get different views on this. EICR testing seems to have changed over the years & not by us the Electricians...
