Minor works or EIC??? | on ElectriciansForums
Discuss Minor works or EIC??? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
G
Graeme Harrold
I have just fitted an external light on a commercial property to illuminate a sign. The property has recently been rewired, and the circuit for the light (dedicated 6A) was fitted but not completed. Im guessing its going to be an EIC for the 1 circuit as I hd to install a switch and connect the existing wiring at both ends.
All fully tested, so I have all the necessary readings for either document. Downside is I could not see the whole of the wiring, wich I will duly note as pre-installed.
Advice warmly welcomed
Yeah, a dead circuit isn't a circuit really, even if the cable was already installed. You have put the circuit into service, and so in effect you have created a new circuit, which warrants an EIC.
Reply to Minor works or EIC??? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
You can obviously put N/A in some of the boxes like the cable size etc because you haven't used any, you can do a loop test at the thermostat and...
https://professional-electrician.com/technical/replacing-a-consumer-unit-in-a-dwelling-niceic/ All circuits should be tested
