minor works | on ElectriciansForums
Discuss minor works in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
J
jimmylaud
how many minor works could you use for one job could you say do one for a alteration and one for a new circuit? thanks alot
You would need one for every altered circuit worked on and an EIC for the new circuit.
As you would have to do an EIC anyway why not put everything you have done on in and in the remarks area just state what you did to that circuit ie spur added. Saves a lot of form filling and repeating the same info over and over and over again.
Chris
If you add a new circuit thats not a minor works that an installation certifcate ,altering a circuit ,or works on a circuit IE changing a pendant where you break the circuit requires a minor works ,
so if you are replacing several fittngs or adding sevral test at the end as long as its the same circuit one certifcate , and if its a minor works adding extra sockets in a kitchen say , thats notifiable too
Reply to minor works in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
If this is a genuine change then throw it back at them, a nicely worded email explaining the additional testing requirements and paperwork charge...
Do a minor works for connecting the new gas boiler and add some notes regarding the addition of the bonding.
