Mira, Triton, Aqualisa electric shower repairs | on ElectriciansForums
Discuss Mira, Triton, Aqualisa electric shower repairs in the Australia area at ElectriciansForums.net
Its certainly seen as a throw away appliance much the same as a freezer etc nowadays
If the repair can save the customer a lot of money then its worthwhile,however to do that puts a low ceiling on your profit for those repairs compared to a straight swap
So my view would be yes its better to renew them than change them
I strive to offer repairs to electric showers in the Brighton and Hove area but find that it is better economics to replace.
Is this a general view?
Craig
Plumbing and Electric Shower Repairs in Brighton and Hove
Plumbers in Brighton and Hove - all plumbing work carried out.
Yes it is, an 'engine' for a shower can cost ÂŁ80.00 while a new complete shower with brand spanking attachments can be had for less than ÂŁ100!
We check connections etc. on all shower jobs but after that, we replace.
I just check the connections etc and the thermal cutout is belling out. If they are all fine I tell them it needs replaced. The ones with circuit boards in them are a definite repacment job.
Can't answer yours but request info. on best shower to install in old cottage with oil-fired system ie. NOT a combi so requires me to heat a large immersion heater just to get a shower unless I get an electric one installed. Are Triton the best? How much can I expect to pay including plumbing through wall to kitchen next door roughly, as I do understand job would first need to be seen by installer. Unfortunately I'm in Suffolk, so too far away for many on this forum! Perhaps there is somebody nearer? I live in Stowmarket area not far from Wattisham air base if that helps. About 20 miles from Ipswich, 15 from Bury St. Edmunds. Thanks
Well this has certainly sparked a little debate, however I'm pretty sure this is just a ploy to get his website advertised!
In the spirit of things, though, yep, I reckon you'd have to be mental to try and repair, you can get a replacement for sixty bucks and then you've got all that lovelyu old copper in the old model to scrap!
Same here, I have never repaired a shower - nearly always it is a water leak, or the water won't turn off fully, the parts are ÂŁ50ish, whereas you can get a brand new 8.5kw for ÂŁ60-70.
I always tell the customer that if one part has worn out, there are bound to be other things going too, so it is not worth repairing.
Alan.
i agree with everyone else its not economical to repair electric showers,just replace if your doing the plumbing as well some miras are lh connect but check first triton were doing a base plate were you could extend cables/plumbing dear but gets you out of trouble dont know if its still available though
Reply to Mira, Triton, Aqualisa electric shower repairs in the Australia area at ElectriciansForums.net
M
Aqualisa electric shower, mains water entry point blanking plug Hello, Im looking for help in tracking down a replacement part for an Aqualisa...
Marty
M
Heh I know the brochures for courses with stock images of women using tools in random scenarios but when you're there it never happens, it's all...
