Gigsy
Hi everyone,
Does a mirror light on a lighting circuit need to be on an isolation switch, fused spur or can it be wired directly on the lighting circuit?
My thoughts are;
My job is to protect my cable, there I have no issue, i.5 mm2 cable to mirror light
Local isolation, the mirror does not need maintenance, if you want to change the mirror you can isolate it at the consumer unit.
My conclusion, i can wire it directly off the lighting circuit.
Before you say it, i know how to wire it, I won't come off another light, I will wire line and neutral from the junction box.
My thoughts are;
