Mislaid metrel tester lead | on ElectriciansForums
Discuss Mislaid metrel tester lead in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
coventry
Hi ive lost my mains lead from my metrel instaltest would i be able to use my kewtech r2 plug in place of by plugging in the other leads to do my Zs tripping times etc at sockets when testing
The Mains lead is a be-spoke piece of equipment I have the same tester, if i was you i'd buy a replacement, you may need that lead when calibration is due, good luck
Reply to Mislaid metrel tester lead in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Having some issues with my companys fluke 1662/1663 tester. Zeroing 2 leads for continuity test we get the value 0.08 which is expected. The issue...
"When stoned..." Brilliant!
