gazdkw82
for some reason I'm struggling with resistors more than anything else in the electrical science (202/203) course material.
I have a table with 6 examples, each having 3 resistors in parallel and a total resistance. Problem is a lot of the figures are missing and the question asks to find the missing resistances.
I'm not even sure where to start. For example the first has
R1= 120ohms
R2= unknown
R3= unknown
Tr= 48ohms
For resistance 1 i did 1/120 which gave me 0.0083
If I knew the rest I'd devide them all by 1, add all those values up then devide that by 1 and I'd have the total resistance but I'm not sure how to approach missing resistances, especially as no other information (voltage or amps) ) have been given
Reactions: Dan
reckon that dash means it's only two resistors in parallel, not three. so you only ever got to find one missing, which makes sense for the 202. i just filled a whole page of working trying to solve for two unknowns! sod that.. :D
I'm confused by the table as some boxes are blank and others have a - in them. Does the - mean there is no resistor? If that is the case you only have the one unknown which is easy to calculate.
1/RT= 0.0208
1/R1=0.0083
0.0208-0.0083=0.0125
1/0.0125=80
R2=80 ohms
gazdkw82
leicester
United Kingdom
Electrical Engineer (Qualified)
Missing resistors
Electrical Course Trainees Only
gazdkw82,
gazdkw82,
