MK essential range , anyone tried it ? | on ElectriciansForums
Discuss MK essential range , anyone tried it ? in the Electrical Tools and Products area at ElectriciansForums.net
I like the Logic range, my first choice usually, but not seen the cheap one in the flesh (or plastic) yet.
Watching video now, the essentials range looks rubbish!
[automerge]1589553086[/automerge]
Cheap FCU grip looks as if it holds the wires, not the outer sheath?
My pal bought two light switches, from the Essentials range, and I couldnt fit them because of exactly what JW showed...they stick out too much at the back. he liked the idea of the cover plate over the screws, but they're just flimsy stuff IMHO. Not worth trying to save a few pennies.
JW promises a video trying to overload them and/or otherwise set them on fire, looking for ward to that :)
Also I had not realised that 13A sockets don't need to be DP switching, i just assumed they were all like the MK logic style. Assumption making an --- of me again!
Out of interest, who do you use for general white accessories?
At the moment mainly Scolmore
Back in the mid 80's we moved over to using Crabtree as our biggest customer was a local health authority and when MK had that stupid twist shutter that allowed 2 pin plug to be used they were barred from use in the NHS by a HTM before that point it was a mix of MK and Crabtree mainly down to spec on the job
but if there's a cover plate over the screws, how can you tell if the screw slots are aligned vertically?
The video explains the range well, saw a few samples. They look and feel like cheap tat, I've never liked accessories made of polycarbonate, too flexible and meltable. I hate that the MK Logic Plus euro frames are no longer made of the urea formaldehyde type stuff and are now made of soft ploycarbonate. The screwless frame looks really ugly as well, I've never understood screwless plate stuff, it almost always looks more conspicuous than standard plates with screws. I would certainly not recommend the essentials range, I don't know what the designers were thinking! The same goes for that terrible Crabtree Instinct range. We were sent some samples of that and decided we were not going to ever use that either.
I don't want to fit cheap garbage accessories, I want to fit well designed, robust and reliable ones. When will manufacturers understand this?
I remember when the Crabtree sockets and switch fuse connection units changed from good to the current design with small crap square terminals made of steel. An Electrium rep visited the local wholesalers and had to leave there early due to all the abuse he was getting from the local electricians. I miss the huge round brass Crabtree terminals, especially on the FCUs where the terminal layout was perfect for neatly dressing the wires and they would accept 2x 6.0mm conductors. Why do most manufacturers lay the terminals so the in and out terminals are all crossed over from one another? And why do they make the terminals square?
I was given one at an Elex show but too embarrassed to use it....why oh why do they do this?....probably to shift many units = make more money, someone retires on a fat bonus...someone should have gone to specsavers !
That is disappointing, as one thing I might need soon is some grid switches. Any suggestions of a decent choice?
Reply to MK essential range , anyone tried it ? in the Electrical Tools and Products area at ElectriciansForums.net
Also good for cutting strands of cable armour, although I try to restrict their use to copper.
nicebutdim
N
When I first started, I stripped out a house for a rewire and got my hands on a switch with an inlay and transparent cover. Filled it in with...
