mk grid for kitchen appliances? ways to wire? | on ElectriciansForums
Discuss mk grid for kitchen appliances? ways to wire? in the UK Electrical Forum area at ElectriciansForums.net
Smudge
going to install an mk grid system (6 way) for a kitchen. The kitchen has 4 double sockets, 2 ovens, fridge, fridge/freezer, dishwasher and an extractor. What are peoples opinions on best way to wire this? Would you have a seperate circuit for the grid, looping the feeds at the back of the switch, or would you incorporate it all on the kitchen ring. I haven't been given any of the specs for the appliances, only been given a layout and said they don't want fused spurs all over the walls.
Any opinions or alternatives appreciated.
I guess it would depend on amount of switched feeds. I go for an easy life and make it a dedicated circuit for the grid.
I once had a new build block of flats that everything in the kitchen was required from a panel grid switch, now that was a busy backbox. I think i had five incoming circuits and 12 outgoing feeds. It started off dressing all planned in the back but still looked pants in the end. I don't envy any sparks trying to work out what went where even after it all was labeled. The 10mm for the cooker took most of it up.
I always find that a crow bar and lump hammer helps to get the front plate on!
Reply to mk grid for kitchen appliances? ways to wire? in the UK Electrical Forum area at ElectriciansForums.net
Thank you for fast response. The reason I asked is because I had read elsewhere online: "Electric ovens have a wattage rating that tells you how...
